I turned the water on to my sprinkler system last night. First problem was that I forgot to shut the drain valve. I was wondering why I wasnt getting any heads to spray when I went to the valve to find a small growing pond. Closed the valve, problem solved.
Next I noticed a small leak in one of the fittings on the water supply line. Can anyone tell me what these fittings are? Freeze protection?
http://dimensional.com/~rotaour/sprinkler.jpg
The two things on top of either upward pipe are what I'm talking about. If you look closely you can see a bit a spray coming from the one on the right. They have an opening about 120deg I assume is to spray water away from the house when they break.
The entire assembly is soldered together. What kind of torch will I need to break this loose? I assume a typical propane torch will not get hot enough fast enough, but I'm not sure as I've done no soldering of copper pipe before.
Both of these fittings also have a hex cap on top(see photo), which is also soldered. Is it possible to fix the fitting by removing this cap or is the whole unit junk?
TIA
Matt
TIA
Matt
