Help with Bosch Oven not heating
Joe
Hi All,
My bosch fan oven has went on the blink. The digital time works but
thats about it.
When you turn it on the fan at the back dosen't come on, the light
dosne't come on and it dosen't heat up. I think there must be a fan in
the top that cant be seen cause i can feel air coming through the top.
Whats the most likely fault. - Was looking at a oven repair site and
it suggests generally a faulty
fan oven element.
Any help appreciated as my CH just went on the blink as well this
week...(luckily covered by BG)
Cheers
Joe.
Phil L
Frank said:
Luckily???
Good luck!
I was just about to say that :p
To the OP:
BG will probably say that you need a new boiler and they will fit one for
????, yes it will be four figures, normally between £1800 and £2500.
After they've broken the bad news, ring a *competent* plumber and ask him to
have a look at the boiler, he will probably have it running for less than
£150, meanwhile cancel the DD to BG.
Joe
To the OP:
Thanks for utterly useless replies guys. I'm sure if everyone was as
clued up as you with CH then BG cease to exist.
Bob Eager
Sorry, but it's true. BG couldn't even change a ball valve in our header
tank properly - had to call them back with water pouring through the
ceiling.
When the boiler died (and I suspect they edged it on its way) they
quoted 3800 to replace it. I had the same work (more actually) done by a
reliable local guy for 1900.
Joe
ceiling.
The point is I dont give a toss about peoples opinions of BG. the post
wasnt about that...
Phil L
Don't mention it.
Phil L
Wow. Nice comback - you must be the life of the party down your
dominoes club.
I don't play dominoes, nor do I go to a club, but yes, I am the life of the
party, and thanks for asking.
BTW, don't get your panties in a wad just because the topic has drifted away
from your non working oven - you were likely to recieve many replies to your
problem but once folk think that you are a crying ****, they are likely to
ignore you completely.
HTH
geoff
wot e sed
Joe
HTH
Fukc you - i dont care about the oven now. Theres always some wakners
on newsgroups who've got feel they have to reply to posts - nomatter
what shit they talk.
TFFA.
Phil L
Calm down tiger, you're making yourself look like a twat.
newsgroups are like crowded pubs - anyone can say anything they like and
it's not unusual for a thread about mixing concrete to drift quite quickly
onto something totally unrelated, like sharks or peanut butter, this is
where you seem to be malfunctioning - you seem to think that this thread
*belongs* to you and that you somehow control it - it isn't and you don't,
nor should you expect the answer to all your troubles within minutes, hours
or even days, you might not recieve one at all, this is no reason to spit
your dummy and start throwing insults about.
Piss off shitlips
Oven not heating. 0
Bosch dishwasher not heating 0
Installing a Bosch Oven 7
Help with gas oven 0
Hotpoint oven not heating 1
Oven not heating up? 5
Oven will not heat up 14
Bosch oven circuit diagrams? 1
