I have no delusion that this thing heats the pool to any significant
temperature.
TOH never said heating the pool was the _main_ point at least I didn't
catch it. Maybe they mentioned pool heating first?
Yes, that's how it started. TOH plumber, Richard T meets the
homeowner and the discussion is about heating the pool.
The HO says it's been hard keeping
the pool warm enough, the backyard is shady, that he has researched
other pool heating systems, wood burning, solar, hasn't got a roof
with exposure for solar, etc. Richard adds the benefit of making
the AC
more efficient when he describes to the HO how the thing works.
And then to confuse things even more, Richard also says
that the AC will use the same electricity as before, but
you'll be getting heat for the pool too. So, which is it? That
it improves the efficiency of the AC, or not? I think it
does. One thing I think everyone agrees on is that when
the pool is heating you could turn off the AC condenser fan.
That for sure saves money. But, I wonder if they even do
that? It would save energy, but it would also complicate the
install because now you have to modify the AC equipment
to selectively kill the fan. What about things like AC
warranty? What about that for the system anyway?
I mean if say the compressor fails, what if Trane says
the system was modified, screw you? Maybe that
wouldn't happen, because the servicing company would
just put it in as a warranty claim anyway.....
I think they were wrong to mention pool heating at all because
this isn't going to heat the pool enough to make a difference.
I'm in central NJ (like you).
I didn't see where they mentioned the location of the house in question but
since it's TOH, it's likely it's New England. Like us in NJ, only
worse. With the trees that guy had next to the pool, that water must be
freezing. Reminds me of swimming in the cold clear lakes of New
England. Nice water but cold, cold, cold.
Yeah, I was wondering where it was located too. I came to the
same conclusion, that it was probably NE.
The big thing missing here is any report on how well it worked.
You would think they would come back after a week to
see the results. I don't doubt that it will heat the pool some.
The real question is whether it's enough to make the
whole thing worthwhile.
I think we're on the same page with regard to that. Around
here a typical inground pool has a 200K to 400K btu heater.
And if you've used one, you know that it takes it many hours
running full blast to heat the thing. With say a 3 or 4 ton AC,
you're getting what, 45K maybe 55K btus? And most of
the time the typical AC is not running anywhere near constant.
Mine on typical summer days runs maybe 25% of the time,
from 11am until 8pm or so. And very little at night.
So, you get it part time.
