Hairline cracks - external wall
Mat Dunning
being the paranoid type of person I am with warnings of doom and gloom in
papers about the hot weather this year bringing on subsidence, I thought I
would do a quick check of the exterior of my house.
At the back of the house, above a window, I noticed a hairline crack (and
by hairline, I mean that I can't put my finger nail in it) following the
mortar line upwards for about 5 bricks up.
On the front of the house, just below the main window, I also noticed the
same type of crack, which ends about 2 bricks from the soil.
I've carried out a few searches on the net, and one article, said that it
was expected that after 30 years (about the age of our house), to carry
out a bit of "Tuckpointing"
So what am I to do ? Panic ?
Is it best to get a builder/inspector round to have a look ?
Should I try to fill hairline cracks myself, and what with ?
Should I just mark the end of each crack and check periodically that the
crack has not extended (or will it continue to extend regardless of
temperature/ground movement)
Thanks for your time.
regards
Mat
gamertag : nextgenconsoles
R P McMurphy
| Hi,
| regards
| Mat
id just re point it to match existing colour and watch for further movement.
rpm
dg
Brickwork can move naturally either over time, or by season to season, and
cracks are generally nothing to worry about unless excessive.
You could monitor the crack to see if it is progressive movement, but unless
it gets above 3mm wide and growing, then it can be left. It may well get
longer, but that does not necessarily mean there is a problem. The position
of the crack is a common one, as the lintols or frame can flex, and the
large panels of brickwork either side of openings expand, contract, and
move.
Tuck pointing is a type of pointing ( the mortar joints are made to project
past the face of the brick) and is uncommon on normal house walls.
By pointing the cracks you will most likely to be left with an obvious and
unsightly joint - for no real benefit. If you want to fill such a small
crack, then better to use a clear silicone mastic and just use enough to
fill the crack - not the whole joint.
dg
Mat Dunning
and cracks are generally nothing to worry about unless excessive.
unless it gets above 3mm wide and growing, then it can be left. It may
well get longer, but that does not necessarily mean there is a
problem. The position of the crack is a common one, as the lintols or
frame can flex, and the large panels of brickwork either side of
openings expand, contract, and move.
project past the face of the brick) and is uncommon on normal house
walls.
and unsightly joint - for no real benefit. If you want to fill such a
small crack, then better to use a clear silicone mastic and just use
enough to fill the crack - not the whole joint.
Thank you for your reply. Very helpful.
cheers
regards
Mat
hairline cracks in wall 2
hairline cracks in walls 2
Cracks in External Walls 5
Crack on external wall 1
Hairline cracks 3
hairline crack 3
Hairline cracks 4
Hairline cracks 5
