As noted previously, earth ground and safety ground are two different grounds required by the National Electrical Code (NEC). A connection to water pipe is no longer sufficient to earth an AC electric system. That connection to water pipe remains to remove elecricity from water pipes. Never make a connection to water pipes to dump electricity into those pipes. This being so important for human safety especially in bath, shower, and sinks.
Current code calls for a dedicated earthing connection. To exceed code requirements, that earthing connection must be as short as possible, no sharp bends, no splices, not bundled with other non-earthing wires, and the ground must be shared by all incoming utilities. That means each the CATV wire must drop down to connect to that single point ground before rising back up to enter the building. This paragraph only discussing earth ground.
Volts500 has provided a good summary of household grounding for human safety, in the newsgroup alt.home.repair entitled "Grounding Rod Info" on 12 July 2003 at
http://tinyurl.com/hkjq
A recent discussion in the newsgroup alt.home.repair was "Easiest way to ground a computer" from 5 May thru 10 May
2005.
The only place I would most want three wire outlets is in the kitchen. Especially a dedicated outlet to the refrigerator that cannot be on a GFCI, must be on its own circuit, and that must have a three prong outlet. Kitchen counter tops and things like the garbage disposal, electric stove and oven, etc all do need that third wire safety ground. Elsewhere in kitchens, bathrooms, outside outlets etc can be GFCIed. Also required now is that all bedroom outlets be AFGIed. Same should be installed on any interior receptacle that lights a 'live' Christmas tree. These provide safety not made available with three prong outlets. This paragraph about making power wall receptacles for human safety.
If running interconnected electronic appliances, then either all should run on safety grounded three prong outlets OR all must connect to a power strip so that equipment grounds share a single point connection. For example, computer, its external modem, and its printer should somehow share a common equipment ground. This paragraph more about equipment grounding for transistor safety.
