Probably what he purchased was an "equipment grounding bar". Two equipment
grounding conductors (bare or green wires) would be permitted to be
terminated under one screw in that case. The neutral (white) wires need to
be terminated with only _one_ wire per screw. Also, if he takes a closer
look at the existing neutral bar he should be able to find a way to use the
holes that he says are inaccessible.
These people exist only to scare the crap out of unsuspecting
homeowners like yourself.
No, "I-Shit-fer-brains", the majority of us in this NG try to get the
correct info to folks so they can make safe electrical installations.
Whether or not those folks heed that advice is _their_ business, but at
least they have the correct info. GET IT?
They always have this wild story
ready about your screws suddenly flying loose all by themselves,
and the wires just JUMPING out of the holes, all by themselves,
and well, I'm sure you see the picture.
Now you're just showing your usual ignorance. The wires don't have to "jump
out of the holes" to cause a problem. A loose connection is enough to cause
problems. I believe others have covered the reasons why a neutral wire
needs to be terminated by itself, besides, discussing _anything_ electrical
with you is a waste of time.
Two questions for you:
1) Do you know how to -properly- run wires inside of a box???
Hint: the answer has to do with routing the wire so that it
can't really go anywhere else *but* in the hole. This is done
by your sizing and bending.
Geez, what a moron.
2) Do you know how to tighten down a set screw and then test that
your wires are not going to pull out? No real hints on this
one, sorry <g>
Well, that pretty much rules out any discussion of torque limiting
screwdrivers or wrenches.
If you can answer "yes" to both of those questions, then I suggest
you trust your instincts and ignore the doomsayers.
That's why this is your theme song Tomi Boy:
http://firesafety.buffnet.net/
and, unfortunately, anyone taking your electrical advice will most likely
hear it too.
When their
earthquake comes (the only thing that will rip your properly
installed wires from their holes) then I dare suggest you are
going to have some other problems to deal with, like maybe the
entire power grid being destroyed.
Now THAT's the "Mr. Practical", Tom Pendergast who we know sooooooooooo
well, practically stupid, that is.
At the very least, use the new extension holes for two wires each,
just as it is labeled. Every new circuit I've wired for the last
30 years I've put the ground and neutral for that circuit in the
same hole, and at last count (OK, so this isn't earthquake
country) they are all working just fine.
That's funny, just SIX MONTHS AGO you tried to claim that you had 20 years
in the trade (snicker). Why are you trying to come off like you're an Old
Salt? We all know that you are a self-appointed internet armchair
lesstrician who took a Sally Struthers "get your degree" electronics course
20 years ago, found your electrician's license in a box of CrackerJack, and
somehow arrived at the conclusion that you are actually a bonafide
electrician. I'd give you a week doing real electrical work before you
either seriously injured/killed yourself/others doing some stupid shit or
got pummeled by other electricians after you repeatedly endangered their
lives.
But then again, I know
how to tighten down a set screw and to size and bend two wires
so they fall into the hole just about all by themselves.
Using your weenie electronics tools? BRAHAHAHAHAHAHA. YOU'RE A HACK TOMI
BOY. SSDD with you Tom "Firebug" Pendergast.
