Granite Hearth
Richard
Hi all
just laid a granite hearth in two pieces one inside of the chimney and
the other outside. I have a small gap where the two pieces of granite
meet which I need to fill with something black, any ideas? could I
just use black mastic or something similar?
Richard
E
EricP
Hi all
Richard
Get a concrete colour (black/grey) and dye some mortar mix.
Grunff
Sounds exactly like the hearth we laid 3 weeks ago, only ours is slate.
I filled the gap with mortar (it's quite a big gap, about 20mm), then
finished off with charcoal black tile grout. This gives a smoother
finish than mortar, and is totally matt black. B&Q stock it, as do
bigger tile shops.
Andy Hall
Hi all
Richard
If you talk to a granite supplier (stonemason), they should be able to
recommend or supply and epoxy filler. I have this between a worktop
and an upstand and it's effectively invisible.
Check about heat resistance for this application, though.
..andy
To email, substitute .nospam with .gl
Richard
Thanks all I went for the easy option in the end, found some midnight
black grout at B'n'Q after searchng for the charcoal one suggested,
this was ready mixed and has done the job a treat. Lets hope it
withstands some heat!
Cheers
Richard
granite hearth installation 0
Restoring Granite Tile Hearth 0
hearth 0
hearth 5
Fitting hearth 2
extending hearth 3
Slate hearth 6
constructional hearth 1
