GFCI Noise
CL (dnoyeB) Gilbert
Usenet Archive
The GFCI in my bathroom has always made a very slight humming noise. None of the others make this noise. It seems to work and the Test button works. Should I replace it anyway? ever heard of this?
PoP
Usenet Archive
I"d replase it pronto, and if the next one does the
same thing, there's something "differnt" somewhere. A
GFCI, AFAIK, only hums when it's defective or under
heavy load. The TEST button is an indicator of whether it's working or not, but it's NOT necessarily an indicator that it's tripping WHEN it should, or of how much protection it's affording. Stuff happens, so check it out. Is this new? How long has it been doing that? Etc.
While you're at it, check out the rest of the things on that line; is there a heavy load there and is the switch rated to handle it? Is everything else working correctly?
Cheers,
"CL (dnoyeB) Gilbert" wrote:
Bud (archive)
Usenet Archive
Good chance it is the transformer for it's power supply. Same as flourescent ballasts, the 60 Hz changing magnetic field can cause physical movement which you hear. If this is the source and it is not a nuisance, it can be ignored. If it is loud enough it is a defect and could probably be replaced under warranty.
Bud--
CL (dnoyeB) Gilbert
Usenet Archive
Bud--
Yes, thats probably it. I remember one time brushing my teeth in the shower and wondering if I brushed at 60Hz because so many external sounds were 60Hz. I wonder what speed eurpoeans brush at?
Anyway, its a 3 year old house, and its been humming since I got there
1.5 years ago. Everything seems to work, and there is usually no load on the circuit. It hums regardless of load though.
Tekkie®
Usenet Archive
CL (dnoyeB) Gilbert posted for all of us...
I don't top post - see either inline or at bottom.
It doesn't know the words...
Tekkie
lisac
