I've bought this GE/Jasco 55w 2D fluorescent fixture. The fixture is not as advertised because the package states "five 60w bulbs" is incorrect. The dome is too thickly frosted to achieve that claimed light output. Whoever designed this fixture must have went by the raw lumen output of the fluorescent tube, and probably never tested the actual fixture with the dome in place. I've contacted GE, but they say "contact Jasco". So I contact Jasco. Either the person responding to my email doesn't understand this, or they don't care. In short, Jasco says: "We can't make the bulb brighter, so just bring it back." ???? So of course I try to explain it to them again, not the BULB but the DOME is the problem. Either make the dome less thickly frosted, and/or at least fix the wattage claim on the box. I like the fixture, except the lower than claimed output is a little disappointing.
This is a common complaint of compact fluorescents.
I would take light output claims exceeding that of known available incandescnts (including incandeascents with rated life as low as 750 hours) of as low as 2.5 times the claimed power consumption with skepticism in addition to at least a grain of salt, and claims of producing more light than an incandescent of about 3.5-4 times the claimed power consumption with at best "hostile skepticism".
Producing same light as an incandescent of 1/4 the claimed power consumption is easier, due to a few various "economies of scale" that favor higher efficiency of higher wattage lightbulbs. However, even good brand/model compact fluorescents in good conditions only produce about as much light as better incandescents of 4 times their nominal wattage. For example, I have found the best 13-15 watt compact fluorescents generally to fail to significantly outshine the brightest 120V 60 watt incandescents, and I have found them more noted to fall short of "60 watt incandescent equivalence" than to exceed such. You may sometimes need a compact fluorescent of wattage in the 18-20 watt range to produce as much effectively usable light as a 60 watt incandescent, and in more extreme adverse cases require 23-25 watts of compact fluorescent wattage to get you as much useful light as a 60 watt incandeascent.
And beware - recessed ceiling fixtures are a bad case, harder on "screw-in" (ballast-included-in-"bulb") compact fluorescents of wattage more than 20 watts, and ones as low as 15 watts get to claim something special about being rated to survive the heat endured in recessewd ceiling fixtures. (HINT: Compact fluorescents do not produce much infrared, produce more non-radiant heat [materializing in the fixture as opposed to elsewhere in the room] than incandescents of same wattage, heat up fixtures as much as incandescents of about 1.5 or more times as much wattage, and tolerate high tem,peratures less than incandescents do!)
Not only do ceiling fixtures, especially recessed ones, as well as small enloclosed fixtures compromise the life of many compact fluorescents and most of ones of wattage over about 13-15 watts and probably nearly all of wattage over 20 watts, this can compromise light output, color of the emitted light, and color rendering properties of the emitted light.
In a somewhat bad case, I have seen an installation (visiting many dozens of times night and day) of apparently 13 watt quadtube units in recessed ceiling downlights where the light output of each I have never estimated to significantly exceed that available from 40 watt "standard" incandescents.
I do encourage usage of compact fluorescents, but I do warn that they have some "pitfalls"!
- Don Klipstein (,
http://www.misty.com/~don/cfx.html)
