Gas cooker connector
Guest
I've had to disconnect my gas tumble drier in order to investigate a
'squeek--bang bang' from the drum. (combination of failed rear bearing and a
penny in the works).
The quick release gas connector (as in cooker flexible hoses) is very stiff.
Is there a recommended lubricant for these connectors?
E
Ed Sirett
If I came across this problem I'd probably replace the bayonet outlet.
If I was pressed to make a 'repair' I'd very sparingly smear silicone
GREASE (cf. sealant) on the O-ring and/or the smooth surface it mates with.
John Stumbles
with.
If I were a DIY newbie and didn't know what 'cf' means[1] I might think
it meant you _could_ use sealant, whereas Ed is saying use Silicone
grease, NOT sealant.
FWIW I'd be inclined to smear a bit of soap on it. However I have come
across some bayonet sockets that do not seem inclined to accept the hose
connector under any circumstances. (Supply your own pornographic metaphor ;-))
[1] what does it mean, BTW? :)
I mean, I know it means 'compare with' but what does it stand for? Is it a
Latin abbreviation?
Man at B&Q
with.
Indeed. From the latin confer, it's usually used to indicate something
in agreement or in support of, rather than the contrary. A
particularly bad example.
MBQ
