Gas Boilers and Gas Bottles in Spain
Alan
We have a floor mounted oil boiler in an outside well ventilated store in
Spain (1.1m x 1.1m with 1 wall fully louvred) and the 1000ltr oil tank in
the adjacent store 1.1m x 2m again with 1 long wall fully louvred.
The oil boiler has been nothing but trouble, and we're about out of oil,
so are looking to take out both boiler and tank and replace with a gas
boiler with a series of coupled gas bottles, both being in the original
rooms as before.
Our Spanish builder and plumber / gas engineer have said that there is a
minimum distance of 5m between the gas bottles and the boiler which seems
ridiculous, especially as there is a 100mm solid wall between the two
stores.
Any one else had a similar experience or been given a smaller dimension?
Any reference to legislation I can look up will assist no end?
I keep reading about dimensions of 1.4 - 1.5m which we can easily do but
can't translate enough to get a full understanding The builders want to
build a new store for the bottles which will be both costly and unsightly
as it will have to be on the front of the house.
All advice welcomed and appreciated.
PeterD
rooms as before.
stores.
Well, around here (the USA, specifically New Hampshire) we have minimum
distances based on a number of factors, such as minimum distace from the
building for the storage tanks (based on size, more than about 450 ltrs
must be about 10 meters from the building for example.)
The issue here is building codes, and I suspect that the same is true in
Spain. I'd ask whatever agency that does the inspections what they
require, however around here the suppliers also know all the regulations
(they need to know them for their license) and give good advice.
