If I have to, I can settle for the lowest speed, but prefer the higher speed (desert hot garage). Ideas and help appreciated.
I have an old fan out of a Coleman furnace and these are the wires: red and orange coming out of the motor itself (used to go to a Molex plug) and a black and yellow coming out of a speed contol box but not otherwise connected to the motor (also used to go to the Molex plug.) Any clues on how to wire this dang thing up? Thanks...
You may be able to figure it out with an ohmmeter. Measure all
12 resistances, between every pair of wires. Make a table and write
them all down.
If none of measurements are infinite, assume there is one winding.
Find the highest resistance, and assume those two leads are each at
one end of the winding. Now these are *wind*ings, so the
resistance they show to a direct current ohmmeter is not the same as
the inductive impedance they show to alaternating current. The
latter includes the resistance but is higher.
So with a 110 volt a big fan motor might use 10 or more amps, and ...I
don't remember, maybe,... might show 10 or fewer ohms to the ohmeter.
That might be wrong -- you'll know when you measure it --, but I'll
assume 10 for the rest of the process. (I'm not going to try to
measure inducitve impedance, when most people, including me, only have
a resistance ohmmeter. )
So if the black and for example, yelllow, have 10 ohms between them,
what does the black have with the red and orange. Maybe 3 and 4.2.
And what does the yellow have between it and the red and orange.
Maybe 7 and 5.8. So that the total of the two segments, black to
red (3) and red to yellow (7) = 10. the resistance of the whole
thing***. See three stars below.
I don't want to connect the 110 volts across either 3 or 4.2 ohms. It
might burn out the wiring, and it's much more likely the complement of
those numbers is a usable resistance. So I'd rather connect the
voltage accors 5.8 ohms and 7 ohms (and 10 ohms) The only color that
will do this, as this story went, is Yellow. So try all three of
those pairs, yellow and orange, 5.8, yellow and red, ;7, and yellow
and black, 10, and that should give you slow, medium, and fast.
If it does, hook up a rotary switch of some sort to control your fan.
***If it doesn't work this way, if the numbers don't add up quite
close to 10, then maybe there are two or three windings. Let me know
if that's t he case and I'll t hink about what to measure next .
Even if colors are not standardized, I thought the number of windings
was, and I'll have to look at my furnace diagram to see how many
windings that motor has. Hmmm. Maybe it doesn't say. (It might just
have a circle for moter, I thought my fan made too much noise (ran
too fast) so despite the schematic, I connected the common wire to
each of the other two speeds. Unfortunately, they were even faster,
just as the diagram said they would be.
