flush valves
Me
I had a new water pressure regulator installed to replace a failed one. 2
of the flusmasters in the second floor of my house stopped working. That is
they work but it takes about an hour to fill the tanks.
Before the pressure regulator was in stalled I had 120 psi. The new
installation brought the pressure down to 60psi. Could the flushmasters
have been damaged by the high pressure and do they need to be replaced?
The faucets for the adjoining sinks and tubs work. Any help would be
appreciated. Thanks
Mike Grooms
"Me"
It's probably just some rust caught under the diaphram. Shut off the
stop, take the top off the ballcock, put a rag over the exposed hole, and
slowly turn on the water in an effort to clear things out. Replace the
black rubber diaphram while you're at it.
Fill/Flush valves 17
installing flush valve 12
FluidMaster Flush Valve 0
toilet flush valves 8
Delaney flush valves 0
Flush valve ID 4
Mansfield Flush Valve 1
leaking sloan toilet flush valve 1
