1.25 inches is quite a lot of sag. Make sure you have no styructural
failures before you try to level this up. In fact I think 1.25 inches
is almost proof of some kind of serious problem. Better check it out.
I agree, 1.25 in such a small room is a red flag. The floor leveler
will work, but will add a lot of weight. If the structure isn't good,
you're going to make things worse. The base needs to be solid, or the
leveler will eventually crumble from flexing.
Having said that, I have used the cement based self leveling floor
compound with good results. The bag instructions will help you
estimate how much you will need.
The decent stuff is expensive! It might be cheaper to rip out the
subfloor, fix the framing by sistering or shimming the joists, replace
the subfloor, and use a layer of cement board as the base. And if you
can't see the framing from underneath, this would allow you to figure
out why it's sagging so bad.
Some hints:
Have help. You want to mix and place it all before the first bag sets
up much so you will have to move fast, because it starts to set fast.
Caulk every little crack and hole. Although the stuff seems thick, it
will find even small cracks and flow through them. You don't want a
couple of hundred pounds of cement on the lower floor's ceiling.
If you can, get one more 5 gallon pail than you will need bags, and
premeasure the water. As I said, you have to move fairly quickly.
It does self level, but it helps to help it along a little with a hoe.
Use the recommended primer.
When you dump the bags into the buckets, there will be a *big* cloud
of fine cement dust. Be prepared, and wear a mask.
Get a 1/2 electric drill with a big paddle mixer to mix it. It's
heavy and stiff.
Buy one more bag than you think you will need. You can always take
it back.
Good Luck!
Paul Franklin
