Flickering lightbulb
N
Nic O'Demus
Been doing a bit in my late fathers house today.
Noticed a single light fitting was flashing dimly every 10 seconds or so,
but the light was switched off. When switched on the light works normally,
but when switched off it flashes more brightly and more quickly. After a few
minutes it settles down to a dim flash every 10 secs or so. Still doing it a
couple of hours later.
Its a low wattage energy saver type bulb. Could this be the cause, or is it
likely to be something more sinister?
The house was rewired about 7 years ago, so wiring *should* be good.
No mcb's or other devices are tripping.
I'll try a conventional bulb in the fitting when I next go over.
Any thoughts?
Nic.
Dave Liquorice
or so, but the light was switched off.
Is there any other switch controling this lamp, particulary any
automatic switch such as a PIR or timer?
Many automatic switches use the circuit through the bulb as the return
path for the small amount of power the use. Some CFLs can see this and
fire just as you describe. IMHO it's not dangerous per se but the
repeated firing of the CFL I suspect will considerably shorten it's
life.
N
N. Thornton
Hi, 2 possibilities:
1. its on a PIR detector, CFLs and PIRs have this problem sometimes
2. your switch or wiring is leaking or arcing, in which case it needs
attention before anything bad happens.
Regards, NT
Adrian Wint
This one is easy..... the switch is in the neutral not the live!
Its is wiring error which should be corrected ASAP!
Adrian
Al
I have a fluorescent tube which glows mysteriously when turned off -
probably because the switch is in the neutral cable.
Simon Smith
Christian McArdle said:
A third possibility is that some other source of radiation is lighting it
up. Think radio transmitters, microwave ovens, televisions etc.
To discount it, switch the lighting circuit off at the consumer unit. If it
still flashes, the flash energy is not coming down via the electrical
system.
This was my first thought also, especially if it is a regular flash every 10
seconds. Does he live next to an airport or military installation? Could
also be taxi firm, mobile phoe mast, etc etc although only a radar should
give a consistant flash every few seconds.
Simon
F
Frisket
N. Thornton said:
"Nic O'Demus" <[email protected]> wrote in message few
Regards, NT
Or 3. Try measuring the voltage on the switched live - we've had quite a few
with induced voltages from the loop circuit up to 60v - more than enough to
cause a low energy lamp to try and fire when warm.
Regards, Richard
Colin
Or 4. Try a different light bulb. I have a set of very cheap ones which show
this behaviour. (Very annoying in the bedroom!)
I bought a different brand and they don't exhibit the flickering.
Colin
Lightbulbs stuck 16
Lightbulb paint 5
Lightbulb question 15
Incandescent lightbulbs 24
"Singing" Lightbulbs??? 5
Popping lightbulbs! 15
Exploding lightbulbs 9
Washing lightbulbs 24
