fixing small piece of baseboard to ceiling
benpost
got a small cupboard and we have boxed in the soil pipe, the ceiling
has a couple of big holes around where the soil pipe goes up to the
flat above so decided to cut a bit of baseboard to fit the ceiling,
instead of trying to fill the holes. its only a small area and in a
cupboard so going to use grabs like nails. i've cleaned the ceiling as
it was dirty, and wiped clean the back of the baseboard. whats the
best way of applying the adhesive? in spots? lines? going to hold it
up with a long bit of wood til its stuck.
geraldthehamster
It doesn't matter. I'd spread it about a bit myself.
going to hold it
Take a book ;-)
An easier way to fill the holes, if they are out of sight in a
cupboard, is to jam a handful of rock wool insulation in there, if you
have any lying about. It's quite good for staying where it's put.
That's what I've done round the top of the upstairs soil pipe that
comes down inside the dowstairs bathroom.
Regards
Richard
benpost
stuck it up there ok.. as for painting baseboard can i paint straight
on it or should it be primed? its only a cupboard so finish isnt so
important. around the edges/gaps should i use 'grabs like nails' or
standard filler?
benpost
thanks Richard
now the boards in place and i've removed the wood holding it, seems to
have stuck well
what would you do about the gaps and screw hole indentations?
i'm not having it skimmed as the finish isnt that important
can i use normal filler and / or grabs like nails
once ive done that do i need to prime or sand the ivory side of the
plasterboard before painting?
