finding a neutral
H
heating tech
hiya everyone could someone out their help me please,when i install
boiler etc and a new room thermostat is to be fitted it can be ver
confusing as to what wires are what,find the live no problem but alo
of installations i see is where someone has only fitted 3 core cabl
and use the earth wire as a switched live if thats the case always ta
the switched live to warn others,when i install a complete heatin
system and full controls always use 4 core ,
here is my problem which i really hope someone can help please
please can someone help how do you get a true test to find the neutra
i would be extremly grateful if someone could just clear thi
frustrating question up please.
all the bes
ARWadsworth
heating tech said:
hiya everyone could someone out their help me please,when i install a
boiler etc and a new room thermostat is to be fitted it can be very
confusing as to what wires are what,find the live no problem but alot
of installations i see is where someone has only fitted 3 core cable
and use the earth wire as a switched live if thats the case always tag
the switched live to warn others,when i install a complete heating
please can someone help how do you get a true test to find the neutral
i would be extremly grateful if someone could just clear this
all the best
Try looking at the other end of the cable where it enters the boiler or the
wiring juction box near the motorised valves.
Adam
to find a neutral 0
find a neutral 2
finding a neutral 2
how to find a neutral 0
Can't find out if neutral is bound to the ground 3
neutral and ground 8
Neutral Woes 9
Neutralize Muriatic acid 32
