T i m
Hi All,
For reasons I won't go into now I've been left to try to deal with a
bathroom floor and to make it ready to have some vinyl laid (round
'Mum's').
A 6mm ply sheet has been laid but is a <insert varying distance here
(averaging 20 mm probably)> gap from the wall / skirting [1] and I'm
either going to have to take it all up and replace with a sheet that's
actually cut to fir that actual bathroom (?) or try to fill said gap
(so ~20mm x 6mm by ~8m) between the edge of the ply and the wall /
tiles with something?
As it is such a narrow (and varying width) strip I'. thinking of
applying some sort of liquid 'filler' (rather than an infill strip of
some sort) and it probably needs to be sufficiently stable /
stuck_to_the_floorboards so it doesn't lift when the flooring is stuck
down?
I was thinking something along the lines of Gripfill but I know the
real (solvent) stuff might be a bugger to get flat, and smooth and
something like a cement, might not be strong enough in that thickness
to stay down / together?
So, I'm really keen to know if there is anything that would be ideal
for this purpose please as I really don't want to be taking the new
toilet and hand basin up again (but actually want to).
Cheers, T i m
[1] I'm going to take the one length of conventional skirting that has
been 'fitted' away and carry the tiles down to the floor on the two
walls that are tiled. I was thinking of using some uPVC (5mm x
~60mm?) as a trim round the bottom of the shower tray (to hide the
concrete base) and carrying it round as a mini skirting on the walls?
https://www.angelplastics.co.uk/Images/Images_Large/60mm arch ww.jpg
(or in black to match her cabinet work top).
'Mum's').
down?
Cheers, T i m
