Feeling a cold draft (loc
barry martin
C_kubieL
C > Sitting in my living room while watching TV. I can feel a cold air
C > draft move by. I recently put in Celular shades to keep cold from
C > comming from the windows. Also put in a new storm door to reduce
C > drafts from the front door.
C >
C > Is there a good way of targeting where the cold air is from? Also, is
C > it possible it would be comming from the under the baseboards?
You'll have to do a little investigating. The draft could be coming
from around the windows (are the older?). We could feel a draft
coming from the outlets in the living room so put an 'outlet
insulator' under the plate ==> can be purchased in hardware stores.
Is a set of thin foam panels with cutouts for the duplex outlets and
switches.
¯ barry.martinþATþthesafebbs.zeppole.com ®
* Pollytheism: n., the belief that God is a parrot.
c_kubie
switches.
That outlet insulator, is that the same kind of insulator foam pad that
comes with exterior GFCI outlets?
W
willshak
Similar, but a different foam. The interior ones are usually off-white,
while the exterior ones are dark grey.
The exterior ones serve more as a weather gasket, while the interior
ones serve as insulation.
