Exterior paint is peeling off
pravin
I have cedar siding home. The siding is 15 years old. The original
stain was Benjamine Moore oil stain. About five years ago the exterior
was painted with oil stained using Duron oil base stain. For last two
years the stain has been peeling off. Five years ago Duron bought out
moore paint outlet stores in the area. Five years ago I was told Duron
is as good or better than moore paints/stains.
The rear of the house faces west. The south side of the stain is
peeling off. The north side is good, shows very little stain peel off.
The house is two story and have to hire a painter. The painter
recommends acrylic paint and not stain.
I would like to know how two caots of paint/stai will be applied.
Paint/stain entire house with one coat and then apply second coat or
apply two coats immediately. How long the two coats of paint/stain will
last.
Which is better stain or paint?
Some painters are saying they will use Cabot, Maximm, Benjamin or
Sherwin Williams. Which is a better product.
Please advise what I have to do. What type of products are available.
Thank you.
Pravin
m Ransley
Most likely it was a poor paint job, the S side may have been hot from
the sun, or was stained when to damp and cold. Stains are not suposed to
peel, and dont if aplied right. Scrape everything loose off and stay
with stain not paint. Is it possible paint was used last time. Was
everything clean. Cabots has good oil stain, but acrylic will hold
colors better. Read a Consumer Reports ongoing tests of paint and
stains, it will help you alot.
George E. Cawthon
last.
Thank you.
Pravin
Real oil stain soaks into the wood because it is
just oil and a dye or pigment. There is no way a
real stain can peel off since it doesn't really
form a continuous coat.
Some marketed stains are just very thin paint,
especially water based stains and they might
exhibit some peeling.
If the boards are rough, a stain is probably
preferred, even if smooth many (most) people
prefer and oil stain which needs to be done every
little bit but it won't peel.
m Ransley
My real oil Cabots pealed off my deck because I did it when it was to
cold, 65f daytime 45- 50f night time, it was bare wood.
Paint peels off walls 6
paint peeling off walls 16
Will the paint on the handles continue to peel off slowly? 8
Microwave oven paint is peeling 4
Peeling Paint 0
peeling paint 2
Peeling Paint 2
Paint Peeling 11
