enameling bath
dale hammond
has anyone ever used one of the kits before for re-enameling a bath i have
been asked to reurface a bath by work the bath has been done before and has
now started to peel off very badly is the enamel easy to put on
BigWallop
Is the original enamel chipped or just discoloured? If it's chipped, then
toss it out and get new bath. If the original enamel is just discoloured,
then some T-Cut on a cloth can bring back the colour quite well. Even
better if you have one of those car body polishing machines as well. :)
raden
I used a Tubby kit two years ago and it's still fine.
Preparation is everything, it needs a good key if it's going to last
s--p--o--n--i--x
The bath needs to be clinically clean before applying the paint.
sponix
raden
No it doesn't, it needs to be well keyed, which is something completely
different
--s-p-o-n-i-x--
different
It needs to be clinically clean. The slightest trace of soap and the
paint will peel off, keyed or not.
sponix
raden
A few pixels short of the full picture, are we ?
being "clinically clean" has nothing to do with it
If you have keyed the surface, there shouldn't be any traces of soap etc
the surface needs something to key to
Rob Morley
You might have rubbed it down, but that doesn't mean that it's
properly degreased.
raden
properly degreased.
You might have washed it and disinfected it, but with no rough surface
to key to, you would end up with a peeling skin like a brit a few days
after their spanish holiday
Proper keying requires a lot of work, including copious washing and
results in a "virgin" clean surface. There is no grease left
clinical cleaning alone is **** all use when properly preparing a
surface for a coating
Shall we leave it there or do you want to dig a deeper hole ?
Rob Morley
As long as you use an appropriate solvent ...
dale hammond
thanks for all the help i will get a kit from tubby ,plenty of cleaner and
degreaser and they supply the pads to key the bath with althought it looks
like a angle gringer job first of all to remove the cock up previous tenants
made of the bath i will let you know how i get on and the longer it takes
the better on a hourly rate for this one
Rob Morley
made of the bath
Nitromors would probably be kinder to the bath - of course you might
be overcome by the fumes and fall in ...
