Elec. subpanel question
Martin (archive)
Usenet Archive
is it required by code for an MLO subpanel feeder to be in conduit? (residential constr.)
Thanks.
gfretwell
Usenet Archive
Thanks.
nope, you are thinking of taps. That is when the feeder O/C device is on the load side of the feeder.
sleepdog
Usenet Archive
Not sure about the code, or what MLO is, but if the feeder is non-metallic sheethed and would otherwise be exposed on a ceiling or wall I would definately consider metal conduit instead. Just take the NM sheathing off the length you need to put into the conduit. You might need to run the feeder into a j-box with the conduit coming out the other end, unless there is some other approved transition device, from NM sheathed to metal conduit.
I know the NEC specifies that any exposed wiring in a basement, garage or workshop (meaning not run through joists or studs behind sheetrock, for example) needs to be BX or armored cable to prevent the conductors from suffering any damage.
I would assume that the same principal applies to an exposed subpanel feeder. If you're trying to save money by not hiring an electrician I would recommend asking the old guys working behind the counter at the electrical supply house in your town.
That, or pull the proper permit and have it inspected. They'll be sure to let you know what's what.
SQLit
Usenet Archive
Thanks.
Really depends on the installation and the local authorities.
In the SW USA outside would be a yes.
Inside and recessed no.
jstp
Usenet Archive
From www.acronymfinder.com:
Main Lug Only
Mauna Loa Observatory
Medical Laboratory Observer
Meta-Level Organization
Military Liaison Office
Milos, Greece - Milos (Airport Code)
Ministry of Labour/Ontario
Misanthropic Luciferian Order (Satanic cult)
Mode-Locked Oscillator
Mortgage Loan Officer
TKM
Usenet Archive
toller said:
I googled and came up empty.
"MLO" could refer thes days to Model Lighting Ordinance. There's been some ongoing activity in the lighting industry and the dark-sky groups about such things.
TKM
lisac
