On 04/10/2011 08:43, NT wrote:
On 01/10/2011 14:42, John Smillie wrote:
I read that I need a low resistance, say 50 ohms. But what is the
circuit? Form where to where? I can connect one terminal of my meter
to the earth rod but where does the other terminal go?
To the 'general mass of earth' (which does not exist as a convenient
physical terminal...
Re-repost:
In the absence of a fancy earth tester[1], the following simple DIY
procedure that I've posted a few times before will give results of
entirely adequate accuracy:
[Repost from 20/04/1998, Message-ID:<
[email protected]>]
Anyone with a bit of electrical common sense, knowledge of Ohm's law,
and a decent multimeter can measure earth electrode resistance quite
easily. You need to isolate the electrode in question and then find a
way of getting some current to flow into it. A safe way to do this is
to use a double-wound mains transformer with a secondary voltage of
around 24 (exact value not critical). Connect one end of the secondary
via a suitable length of wire to the main earth terminal in the house
and connect the other end to your earth electrode via an ammeter.
Energise the primary of the transformer, and the secondary current which
flows will immediately give you a rough idea of the total resistancein
the circuit, most of which will be attributable to your electrode. For
a more accurate result, drive a second temporary earth electrode (a 2ft
offcut of 15mm water pipe will do) into the ground at a distance of 10m
or more from the one you're measuring. Then use the meter on volts to
measure the voltage drop between the two electrodes. Dividing this
figure by the electrode current measured earlier gives you the earth
resistance. (Reactance in the circuit will be negligible.) Move the
temporary reference electrode to a second position and repeat. Average
the two values obtained, but if they are significantly different, try
further positions for the reference electrode.
[1] Not to be confused with a loop tester for measuring earth fault loop
impedance, which *is* an indispensable piece of kit.
how to make life hard. Just connect car battery between mains earth
and the new rod via an ammeter. So much easier.
That's ok for this particular application where there is a mains earth
to make use of. However with a TT only install you won't have a "known
good" earth connection to take advantage of.
