Dave Plowman
Could someone give chapter and verse on fitting an earth spike - or where
to find the info?
to find the info?
a) try to make sure there`s no gas / water / electric where you plan toto find the info?
Only tip I can give you is to put the clamp on the spike *before*Dave said:Could someone give chapter and verse on fitting an earth spike - or where
to find the info?
An easy wasy to get a spike into the ground in hard soil, is to connectCould someone give chapter and verse on fitting an earth spike - or where
to find the info?
<eleccy board> - we just used galv steel afaikthe latter being much more expensive but lasting forever.
Hit it on the top with a ruddy great big sledge hammer, and it will descend8gh42nfg-vo-mqe-[ said:Harry Bloomfield retched Earth spike onto my recliner:
Dave Plowman wrote on Tuesday (20/01/2004) :
Although that does get done it's not the way to do it. I think theHit it on the top with a ruddy great big sledge hammer, and it will descend8gh42nfg-vo-mqe-[ said:Harry Bloomfield retched Earth spike onto my recliner:
to find the info?
into the ground.
Make sure there isn't a
a) electric cable
b) gas pipe
c) water pipe
d) sewer
e) cable TV cable
f) concrete
under/ in the site.
Damp location is best. Keep it damp (encourage Fido to cock a leg against
it? interesting if you have a small eart leakage??! )
How's that going to work out then?Test frequently.
Better still - fit a RCCB. Save the bother of installing an earth spike.
If it collapses. I'm not sure this is a good idea for an earth spikeAn easy wasy to get a spike into the ground in hard soil, is to
connect a garden hose to a length of rigid pipe. Turn the water on
and the pipe will quickly make a hole for itself in the ground. Then
just push the pike in the hole you have made before it collapses.
Nobutt i CBA to find the original.8gh42nfg-vo-mqe-[ said:Ian Henden retched Earth spike onto my recliner:
I never said any of that, you silly man!in message news:[email protected]
into the ground.
a) electric cable
b) gas pipe
c) water pipe
d) sewer
e) cable TV cable
f) concrete
under/ in the site.
Test frequently.
http://www.cda.org.uk/megab2/elecapps/earthing/index.htm is a fairly goodCould someone give chapter and verse on fitting an earth spike - or
where to find the info?
its extremely silly in a wite-power sight, yu silly mormon.In alt.music.white-power said:Nobutt i CBA to find the original.8gh42nfg-vo-mqe-[ said:Ian Henden retched Earth spike onto my recliner:
I never said any of that, you silly man!in message Harry Bloomfield retched Earth spike onto my recliner:
where
to find the info?
into the ground.
a) electric cable
b) gas pipe
c) water pipe
d) sewer
e) cable TV cable
f) concrete
under/ in the site.
Test frequently.
And whats so silly about making sure there is no
a) electric cable
b) gas pipe
c) water pipe
d) sewer
e) cable TV cable
f) concrete
under/ in the site.
etc???
growl!!!Smile!!!!
