Drier Won't Dry
Mike
I have a GE Washer/Drier stackable set. The element is putting out
heat, and the vent is OK (I cut out about 6 extra feet of vent, but
still no dice).
If I go outside to the vent, I can feel heat coming out the vent, and
the thing spins, and gets the clothes hot.
However, it takes like 2 hours to dry clothes.
The element reads the correct resistance, and it's putting heat out.
Any other suggestions? I have heat, flow through the vent, and all
that, and I can't think of what else it could be.
Thanks.
H
hallerb
still no dice).
Thanks.
disconnect vent temporarily and leave it vent indoors for one load.
does it dry better?
obstructed clogged vent line
or are clothes from washer heavier.
washer may not be spinning them out good, causing too wet trouble,
sopping wet clothes take longer to dry
DerbyDad03
still no dice).
Thanks.
Is the hot air that comes out of the vent moving in a forceful manner?
Is it possble that you have a partial blockage and that you are not
getting *enough* air flow through the vent?
Are you sure the unit is spinning sufficiently?
dpb
still no dice).
Lint trap clean? Full of lint elsewhere because it hadn't been kept
clean before?
What's RH? If you're in one of these areas that has been getting so
much rain than normal, more humid air than you're used to will cause
longer drying times even in a drier.
Stackable units just don't have the capacity of freestanding if that's
what you're used to and comparing against, too...
dpb
One more thing...
Over-filling the drier will reduce its effectiveness, too...
Mike
One more thing...
OK, it's not overfilled, and the washer spins OK, so I don't think
it's an issue of wet clothes.
I like the idea of dis-connecting the vent for a lot and seeing if
that helps. I'll give that a shot.
Thanks all.
dpb
Put a piece of stocking or likewise over it or you may have a
mess...would be instructional to see what it catches, if anything, anyway.
Would possibly help to know if this is new/old drier, new/old to you,
new/old problem, etc., etc., ...
Mike
My dryer didn't work at all in the summer in the basement ; for that
matter, the metal down there was rusting from all the humidity.
Solved by putting up screens instead of windows on the basement, in
the warm season. That dropped the humidity (partly by raising the
temperature, of course; but also by exchanging air).
I suppose a dehumidifier would have the same beneficial effect but
air is free.
And there's always a clothesline for big objects if nothing else.
Ron Hardin
(e-mail address removed)
On the internet, nobody knows you're a jerk.
The drier is new to me, but not really new. We've been in the house
for a year, and seen no difference (a'la Ron's humidity suggestion).
I'll post my results.
Guest
still no dice).
Thanks.
Plugged vent line.
Drier Won't Dry - Part Duex 9
Drier in Bathroom 5
Drier Repair 11
Drier exhaust 2
Tumble driers 14
Tumble Drier 2
Condensing Tumble Driers 35
Washer drier recommendations 7
