Alan said:
Hope someone can help.
I have a dead raccoon trapped under my deck. Problem is that it is in a location I can't reach unless I tear the deck apart. I have no problem letting it decompose naturally but the stench is bad and I am worried about disease.
I can see it through the cracks in the deck and can pour liquid or powder (maybe) on the carcass.
Any suggestions as to what I can do would be greatly appreciated as I am trying to avoid tearing apart the deck.
Thanks.
Alan
Couple of thougts come to mind.
1. I would assume rigimortis has set in so moving the body as a whole shouldn't be a problem. Is there a way to get rope around the animal and drag it out from underneath the deck. I would take a long pole and attach rope to the end of it which would allow you to hook and drag the animal out.
2. If access is truly an issue from underneath, and it was my deck, (I have a deck made of IPE using the ipe-clips hidden mounting system so gaining access under the deck would be a similarly tough problem), I would cut out one or two (depending on the size of the animal) joist width (16" wide) section(s) of decking directly above the raccoon so that you can get it out of there. I would find where the joists are and mark the lines along the center of the joists. Cut out the section(s) of decking to gain access to the raccoon. I would use my Fein Multimaster as it has a saw attachment that allows straight forward cuts with a very thin kerf so that the decking could easily be screwed back in place using the Trimstar screws. Depending on how you cut the decking out, you might have to put in a replacement section of decking. Also, depending on how your deck was built, you could use nails or regular decking screws.
While it would break the clean look of the deck, I would much rather have that than the smell, disease, and infestation of rodents and other animals that will naturally come. This would also allow you to properly treat the area where the raccoon has been as I am sure it has been there a while.
Remember to seal all access point to the underside of the deck so this doesn't happen in the future.
Hope these ideas help.
David
P.S. I plan to redesign the way my deck is sealed off when I complete the steps to make every effort to prevent something like this from happening in the future... Thanks as it was not something I had put much thought into.
