"Dead" Kenmore washer repair Q
GT
Usenet Archive
The above older machine was in the rinse cycle with a large quilt when my brother turned the water level or load size knob to "reset". It stopped dead. It's not the power outlet as other things on the circuit work. Any idea as to what might be wrong or how to test the timer / dial / switch assembly would be greatly appreciated. TIA and Happy Memorial Day...
GT
Edwin Pawlowski
Usenet Archive
GT
All I know is that on our Amana it says not to adjust the level control during a cycle. I have not done it and have no idea what will happen.
Simple thing to try though: Turn the timer to off manually. Start the cycle from the beginning.
Tony Hwang
Usenet Archive
GT
Unplug the washer. Wait ~5 mins. Plug back in and see what happens.
Tony
Appliance Repair Aid
Usenet Archive
GT said:
The above older machine was in the rinse cycle with a large quilt when my brother turned the water level or load size knob to "reset". It stopped dead. It's not the power outlet as other things on the circuit work. Any idea as to what might be wrong or how to test the timer / dial / switch assembly would be greatly appreciated. TIA and Happy Memorial Day... GT Hi,
Model#??
http://www.applianceaid.com/model.html
Some model# helps.
It
You checked the washers outlet with something like a radio/lamp?
Doing so -normally- would not make the washer go dead.
http://www.applianceaid.com/generalwash.html#WLC How a WLC works.
jeff.
BobK207
Usenet Archive
I have an older medium sized Kenmore (1987) & i'm aways messing with the water level 7 load size with no ill effects (so far)
Maybe just a conincidence?
cheers
Bob
lisac
