Cut to length wallplugs
  • Thread starter David W.E. Roberts
  • Start date
David W.E. Roberts
you remeber the 'cut to length' wallplugs?
Continuous length of squidgy plastic and you cut a piece off then used it as
a wall plug?
Just realised that the white version is just right for fixing 2.5mm sq cable
clips, and I only have one length.
Trying to find a supplier, but it is a while since I've seen these so I
don't know if they are still for sale.
Much better (IMHO) that the current 'bullet' plugs you buy by the 100 from
sheds and Screwfix.
TIA
Dave R
BillR
used it as a wall plug?
sq cable clips, and I only have one length.
I don't know if they are still for sale.
from sheds and Screwfix.
TIA
Dave R
You're right, they were good esp when the hole may have been a bit too deep.
Also you could use it instead of a frame fixer by feeding a bit through the
hole in the wood.
My stock is now very low, wonder if Jewsons have any?
David W.E. Roberts
a wall plug?
sheds and Screwfix.
TIA
Dave R
Yeehah! (I think).
http://www.tool-up.co.uk/shop/diy/BSTWVP.html
Roger Mills
John Schmitt said:
Almost certainly not. If you read my FAQ, you will see that there
would be public paranoia about them, never mind the fact that
they won't go down well with vegetarians. As for Rawlplastic, the
nanny won't let you play with that either.
John Schmitt
I wasn't aware that you were supposed to EAT them!
Roger
RichardS
John Schmitt
Haven't seen you in these ere parts for a while, John!
Thought you might have popped up in the midst of the caustic soda
debate.....
cheers
Richard
Colin Wilson
Does anyone know whether you can still get proper fibre Rawlplugs - far
How the hell are you supposed to fix storage rads these days then ?
David W.E. Roberts
stuart noble said:
David W.E. Roberts wrote in message ...
Doesn't say how many in a pack though, does it?.
I am assuming that they are 39p + vat for one length.
Have ordered and will report back.
As you note, the £29+ for a box doesn't allow you to calculate value for
money :-(
Decided not to risk that one
Cheers
Dave R
John Laird
I think my local ironmongers manages to sell them for 40p(*), so that sounds
about right.
[And yes, we did go through the "I thought I might be getting the packet for
that" routine first time...]
money :-(
I have a packet that the individual ones are sold from (having bought the
last few in one size) and it has no indication of contents either. But it
looks as if it could easily hold 25, but no more than 50. In 4 sizes, a box
could be simply a packet of each size, so 100-200. Cripplingly expensive
way of buying a plain plastic extrusion, but what can you do ?
Rick Dipper
My local timber merchant has them, they have a website google for "tomlinson parbans"
Rick
mac
cut to length wall plugs
I noticed an old post from David years ago about cut to length wall plugs
diy4u.co.uk are now stocking the red.green and blue versions
Hopes this helps somebody out
