creeping gutters again...
Guest
Getting fed up with (and increasingly not fit to deal with) plastic gutter
that parts at the joints after every summer, no matter how hard the clips
seem to hold it in place.
Luckily it seems to be the lower sections that seem to move most, so I can
at least reach them when fit enough, but is there some sort of non slip
brace that can bridge the joints? Could I just drill and wire them or would
this crack the plastic when it tried to creep again?
Matty F
I just drill mine and put a stainless steel screw and nut in. Of
course there are expansion joints at the ends but the gutter would
rather pull apart at the glued joins
Guest
Jules Richardson said:
Sounds like it's expanding in the warmer months, and then when the cold
comes it's not able to contract and slide as it should - maybe one of the
supports toward the end of the run is damaged, misaligned, jammed by dirt
etc.?
It can probably be sorted out "properly" - or you can probably get away
with screwing it together at the joints where it usually parts, and
hopefully force it into behaving properly :)
cheers
Jules
Thank's Jules,
I'm afraid the guttering was put in by a bunch of roofers who were not
exactly the most conscienscious of folk as it turned out, and after an
outlay of several thousands to fix the roof up properly a few years back,
the whole roof really needs retiling properly 'again'. So, twas they that
fixed the gutters, and I count myself lucky that it seems to be just the
lower ones where the clip joints just will not stay together.
I've clamped them back with knuckle-breaking force several years in a row
now, but come the Autumn, they are always apart again and the joins are
conveniently over the front and back doors:-(
I think if Matty has got away with bolts that is probably the way to go, or
perhaps another job for my old standby, stainless coathanger wire.
Cheers to you and he,
Phil L
Spamlet said:
Thank's Jules,
back, the whole roof really needs retiling properly 'again'. So,
twas they that fixed the gutters, and I count myself lucky that it
seems to be just the lower ones where the clip joints just will not
stay together.
row now, but come the Autumn, they are always apart again and the
joins are conveniently over the front and back doors:-(
go, or perhaps another job for my old standby, stainless coathanger
wire.
You can't force plastic to do your bidding - it's going to expand and
contract whether you like it or not.
The problem usually lies in the length of guttering used - they are often
supplied in 4 or 5 metre lengths, IMV this is way too long to be used in one
piece as it will contract by up to 100mm if put up in summer and expand by
the same amount if put up in winter, what you need is shorter lengths and
more joints, thus giving the guttering more space to expand and contract
into, so the solution lies in cutting your guttering at 2 or 2.5m intervals
and installing extra jointers.
Black and brown guttering is much worse behaved than white due to heat
absorption, but white is often a lot more expensive, probably for this
reason.
The Natural Philosopher
Andy said:
That doesn't sound right, coefficient of expansion for PVC is approx
0.05 mm/m/C
so a 5m length even over a 50C temperature range, would only expand by
about 12mm, still got be be allowed for but 4" would be a but difficult
to handle.
Tats sounds about right. Problem is that after a few +- 12mm it works
its way to one end and falls out!
Guest
one piece as it will contract by up to 100mm if put up in summer and
expand by the same amount if put up in winter, what you need is shorter
lengths and more joints, thus giving the guttering more space to expand
and contract into, so the solution lies in cutting your guttering at 2 or
2.5m intervals and installing extra jointers.
reason.
Good points, thanks Phil.
Seems, counter-intuitive, that several short bits don't add up to one long
bit as it were!
My old ones were asbestos and painted up a treat with no expansion (only
sparrows nests but we don't have sparrows any more!)
Guest
Andy Burns said:
That doesn't sound right, coefficient of expansion for PVC is approx 0.05
mm/m/C
about 12mm, still got be be allowed for but 4" would be a but difficult to
handle.
I think it's not so much the expansion all in one go, but, rather like
carpet creep, it moves one way and then doesn't move back, then moves a bit
more the next.day etc. And, thinking about it I can now imagine why:
The gutter is clamped down onto the rubber seals, but once it shrinks the
rubber will pop up again and stop it moving back when it expands the next
day. By which token, fitting in the winter might help.
More to this than meets the eye (as usual :)
Guest
The Natural Philosopher said:
Tats sounds about right. Problem is that after a few +- 12mm it works its
Indeed it does - shame I can't sew it down like I did the carpet :)
Dave Liquorice
The joints should slip and slide along the length, maybe they just
need cleaning and smear of silicone grease. While you are at check
any intermediate brackets as well, maybe s smear on them as well. The
joints shouldn't be installed jamed up tight either but with a bit of
gap to allow for movement.
The Medway Handyman
Spamlet said:
Thank's Jules,
stay together.
Sounds like it wasnt installed properly. It rarely is IME, I sort loads of
it out.
Guttering expands & contracts with temperature change as Jules said.
Inside each joiner or fitting is a mark about halfway in and when its fitted
the end of the gutter is supposed to be aligned with that mark. If its
pushed right in the gutter can buckle upwards in the heat or if not pushed
in enough it will slip out.
Nobody though seems to take acount of the ambient temperature when
installing it. For example, if installed on a hot day and not pushed quite
up to the mark it can contract enough o come out.
Uncanny that - they always seem to be :)
You need to check each joint & fitting to make sure all the gutter touches
the mark. I've had to add extra lengths to stop it popping.
Find the shortest run & replace that length with a slightly longer piece.
wire.
If you bolt it together you are stopping the ability to expand/contract.
The Medway Handyman
0.05 mm/m/C
difficult to handle.
I don't doubt you have the figures right, but experience tells me to agree
with Phil.
course you can. What is pvc cement for?
Lock one end of a long run and let the other end do the slidey bit.
FFS you could probably cement the whole lot together anyway.
I've done that is some of my pushfit downpipes cos they kept falling apart..
Nah. glue em all up solid and let the support brackets do the slidey bit
I say!
Matty F
All the expansion joints in the gutter that we recently installed had
a scale with temperatures on them.
I bolt mine together at the joins that are not supposed to expand/
contract. A joiner about 15 mm wide is glued but the glue doesn't hold.
The Medway Handyman
Never seen that before, what a good idea.
NZ seems to have the edge over GB when it comes to gutters.
Guest
Nah. glue em all up solid and let the support brackets do the slidey bit I
say!
That sounds more like it: but then why do they come with these fiddly clips
and rubber seals?
Matty F
Here's the start of the gutter installation.
http://i53.tinypic.com/2ztayw4.jpg
The outlet on the plank is the one with the temperature scale on it.
We have used external brackets because there's an enormous amount of
leaves falling in the gutter and it's easier to clean out without
brackets in the way.
Note the plank is sitting on brackets that attach to bolts that
protrude all around the hut, which is great for the high side of the
hut:
http://i52.tinypic.com/d8ztz.jpg
Note also the solar water heater on the roof. The water from the
gutter is electrically pumped to a huge water tank up the hill. So,
free hot water.
The Medway Handyman
Only ever seen external brackets over here. What do internal look like?
creeping charlie 5
Anti-creep mat 14
Creeping Ivy - whats the legal position? 2
Beams again (again) 2
Gutters 11
Guttering 9
Gutters 2
Guttering 2
