Crazy electrical problem
Bruce
I recently completely re-wired a small house. All new wire, outlets,
switches, breaker box & breakers and most of the light fixtures. Everything
worked fine when I was done about a month ago. Today, I noticed that the
furnace wasn't running. Also discoverd that neither the frig or the washing
machine would run (anything with a 110 V motor). The deep well pump runs
fine (220V) and for some reason, so will a small canister vacum but when I
start that, the kitchen light gets brighter (different circuit too).
I started checking voltages at the main breaker box and found a hugh
difference in voltage between the two legs, like 155 / 85. It doesn't seem
to matter how many circuits are turned on . I turned off everything except
for a single circuit that powers 2 - 100W. light bulbs and the same result.
I suspected a loosed feed wire in the main box but didn't find anything. I
am at a loss on this one. Please help if you can.
bruce
N
Nonnymus
bruce
Darn. I've been around for a few years and have never come
across that kind of problem. What are the voltages on each
side of the main? What is the incoming voltages with the
main flipped off? What are the voltages to both neutral and
to a ground? If they're still weird, I wonder if the power
company might have a bad transformer up on a pole, or if one
of your neighbors decided to do some creative wiring of some
kind on the same transformer.
Please, follow up to this with your explorations and the
eventual solution. In the meantime, you're sure right to
keep everything cut off.
Nonnymus
RBM
This is a potentially dangerous situation, so I wouldn't waste any time
repairing it. At your service, your neutral and house ground should be tied
together. If you are not reading 120 volt to ground from each hot leg at
that location, you have an open neutral on the street side of your panel,
possibly at the utility company transformer or in the meter box
N
none
Everything
washing
seem
except for a single circuit that powers 2 - 100W. light bulbs and the same
result.
I
bruce
Definitely sounds like a loose neutral. This is dangerous because in
combination with other failures it can potentially leave you with a live
ground. Also I believe it can give you strange voltages on your 120v
circuits, higher or lower than it should be.
This newsgroup has sufficiently frightened me of this situation. I would
fix it now.
Thank you,
"Then said I, Wisdom [is] better than strength: nevertheless the poor man's
wisdom [is] despised, and his words are not heard." Ecclesiastes 9:16
Ben Miller
Everything worked fine when I was done about a month ago. Today, I noticed
that the furnace wasn't running. Also discoverd that neither the frig or
the washing machine would run (anything with a 110 V motor). The deep well
pump runs fine (220V) and for some reason, so will a small canister vacum
but when I start that, the kitchen light gets brighter (different circuit
too).
seem to matter how many circuits are turned on . I turned off everything
result.
I am at a loss on this one. Please help if you can.
bruce
You have an open neutral. This is a potential fire hazard, not to mention
the probable failure of many of your appliances. It needs to be corrected
immediately. If the imbalance is at the main panel, then the problem is
likely the utility's. They generally respond immediately to this type of
complaint.
Ben Miller
Bill
If you installed the main service panel, did you torque the lugs for the
main feeds to manufacturer's specs? If using aluminum main wire, did you use
that aluminum wire goop?
Have electric company come out and re-torque your main lugs. If you did not
apply aluminum wire goop, have electric company do this, might want to have
a tube handy.
Note: On the panel printed spec sticker, it will give the torque specs...
Warning! Don't do this yourself!
"Bruce" wrote in message
Bruce
Thank you all for your replies.
The house is currently empty so there is no danger to anyone. The only
circuit I need is for the 220V water pump and that appears to be working
fine. One little bit of information I left out is that the main service
comes into a fused disconnect before it goes to the breaker box. That is
how I was able to replace everything without having the power shut off. I
intend to replace the short alum. feed between the disconnect and the
breaker box with some #2 copper that I have just to rule out this section as
being the problem. If that doesn't fix it, then a call to the power company
will be made.
I will post the results as soon as I get it fixed.
Bruce
Tom The Great
bruce
Bruce
Problem solved!
The problem was indeed an open neutral.
After some testing with an electrican, we found that the problem was with
the #2 feeder wire running from the meter to the inside box. We slit the
outer casing near the meter and water ran out of the cable.
Thank you all for your help.
Bruce
CRAZY ELECTRICAL PROBLEM 8
Crazy Painting problem - NEED SERIOUS HELP 16
Dryer problem making me crazy 11
crazy putty 0
Crazy tiling 30
Crazy light bulb 8
crazy builder lady 11
Microwave gone crazy 4
