RogerT
Thanks. I was thinking of doing it that way but one of the codes I foundjamesgangnc said:Your original idea about using all cpvc is ok. I have used the
sharkbite connectors and have not had a problem. They are expensive
but I used a couple in a situation where I had to transition from cpvc
to pex. It would save you from having to do any soldering. Otherwise
I would go with a solder on female threaded coupler and a male pvc
threaded coupler. It's better to make the cpvc side male.....
http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_29_sec005_par035.htm )
seems to indicate that only approved adapters that are made for transitions
from one type of material to another are allowed. I am not sure if I am
reading that correctly. However, since they do make adapter fittings
(transition unions, I think) that are specifically made for going from CPVC
to copper, I'll probably use those.
The property already has 3 separate hot water heaters and 3 separate..... I'm guessing you have one large hot water heater and you plan
to switch to three smaller hot water heaters? Are you switchng to
three meters as well?
boiler/furnaces -- one of each for each apartment. So, I will be changing
from the one meter that is there now to 3 water meters -- one for each unit.
