RogerT
I am running new plumbing lines in the basement of a 3-unit apartment
building that I own. The purpose of the re-plumbing is to separate out the
water service for each unit. All of the existing plumbing is copper. The
hot and cold copper lines that go to each individual apartment are easily
accessible in the basement, so separating out the water service for each
apartment will be easy because all I will need to do is tie into the copper
lines for each apartment in the ceiling of the basement.
I don't want to use copper, and I think I am probably not going to go with
PEX. My plan right now is to use CPVC pipe and fittings for all of the new
plumbing and to tie that into the existing copper lines for each apartment.
One question I have is whether to use all CPVC, or use CPVC for the hot
water lines and PVC for the cold water lines. My inclination is to use all
CPVC rather than try to save a few bucks on materials by using PVC for the
cold water lines. Does that make sense? Is there any reason NOT to just
use all CPVC instead of trying to use both CPVC and PVC, other than the cost
of materials?
I also have questions about how to connect the CPVC to the existing copper
lines. I can easily solder female threaded adapters to the ends of the
existing copper lines and use male threaded CPVC adapters to make the
connections. But, I think there may be a problem with doing that for hot
water connections due to possible variations in expansion of the two
materials and, therefore, possible future leaks at the connections. I have
seen the Sharkbite and Watts push-on connection adapters but they make me
nervous in terms of how secure the connections would be. And, I believe
there are copper to CPVC adapters that either screw onto, or get soldered to
(I am not sure about that), the copper and then are glued to the CPVC pipe.
I would appreciate any thoughts or suggestions on how to best make the
connections from the CPVC to the existing copper.
And, any thoughts, suggestions, pointers etc. regarding the whole CPVC (or
CPVC and PVC) project would also be appreciated.
Thanks.
of materials?
Thanks.
