Connect PVC to Orangeburg ?
N
njoracle
I have 4" Orangeburg pipe (circa 1968) to which I need to connect a
piece 4" PVC. Are the dimensions for the Orangeburg and PVC the same or
is there some kind of reducer required?
Speedy Jim
Orangeburg is about 4.64" OD and sch 40 PVC is 4.5",
while sch 35 (SDR) PVC is 4.21"
Mission couplings are most often used for underground connections:
http://www.missionrubber.com/
And Fernco makes a similar line:
http://www.fernco.com/1051.asp
You may need to go to a bldg supply house, rather than Big Box.
Jim
N
njoracle
I'm not replacing the Orangeburg. I'm just adding a tee to the outlet
side of a septic tank. The tee will be made of PVC and connect to the
Orangeburg which goes to the septic distribution box as shown below:
__Cap__
! !~~~~_________________------|
----- scum level ------ ! PVC Orangeburg D |
! _________________ Box |
----- water level ------ ! !~~~~ ------|
Technically the description of the Orangeburg is "Bituminous Fiber Pipe"
as shown in this picture:
http://www.sewerhistory.org/articles/compon/orangeburg/orangeburg.gif
Stubby
I crushed my Orangeburg connection to the septic tank by driving a lawn
cart full of rocks back and forth over it. Once I figured out that was
the cause of my backup problems, I dug it up and dropped in some
over-size PVC. Some concrete covered the junctions. No problems in
about 5 years.
