condensate dripping from "A" coil fins and not going into drip pans
I
infoforme121
eleven year old residential split system, inside
"A" coil fins are dripping condensate from the angled
surfaces onto the concrete floor (vertical air handler)
and not into the drip pans. have tried several different
cleaners (including the foamy coil cleaner from lowes)on
both top and bottom of both sides of "A" coil. have added
13 oz. of F22, hi press 150 psig, OAT 86 degrees.
suggestions appreciated.
Tony944
As Stormin said more info. is needed low side and head pressures to start
with.
Your Low side between 75-95 and high side 200-250 it depend on manufacture
and
inside and outside ambient conditions.It would be wrong to say this is it.
