concrete flaking
Discussion in 'Building Construction' started by FiMac, Jul 1, 2004.
  1. FiMac
    FiMac Guest
    Wondering If I could get some advice.
    We just moved out of a home and the landlord is now saying we have damaged
    the concrete. We feel we have done nothing to cause the damage he is
    suggesting.
    The concrete is polished, and a large area, but in just one spot there
    started of a small hole, just on the surface.
    It has grown over time flaking of the polished bit.
    Its about the size of a tennis ball now. Is there anything I can show or
    tell him to prove we didn't cause it??
    Thank you so much in advance
    Fiona
    FiMac, Jul 1, 2004
  2. FiMac
    Phil Scott Guest
    He is a rapacious idiot.... discussion will not work. tell
    him to take you to small claims court if he thinks he can
    win... then advise him to talk to a general contractor on the
    issue and get some proof that you could have caused that.
    Have pictures.. if you go to court show the judge that its
    flaking due to bad concrete...as there is not central point of
    impact showing a chip... there is also such a thing as normal
    wear and tear.\
    You will no doubt prevail if he takes you to court...which I
    doubt he will... has he refunded your deposit yet? If not...
    thats the cause..he is trying to find an excuse not to refund.
    Phil Scott
    Phil Scott, Jul 1, 2004
  3. FiMac
    Tom Baker Guest
    Were I your landlord, I would have wanted you to bring the problem to
    my attention early in its existance. If you don't have fragments or
    photos, I can't imagine what proof you can give.
    TB
    Tom Baker, Jul 1, 2004
