Cistern flush pipe connections
F
Frank Stacey
Just discovered that the flush pipe on a concealed cistern is leaking.
Fortunately no serious damage has occurred. This is a system installed
40 years ago and has not been touched meantime.
The leak is at the flush pipe to cistern join. The flush pipe enters at
an angle. I propose to replace the flush pipe with an L shaped one
which will align the join.
However I don't know how the connections at each end are constructed.
Can someone explain? The cistern end has a plastic nut but I cannot see
how that is sealed and cannot locate a replacement part in any of the
plumbing catalogues - well screwfix & toolstation actually. Flush pipes
seem to be 1 1/2" diam. How is this join sealed?
The WC end seems to use some form of "gooey tape". What is this and how
is it used.
Your collective advice is much appreciated.
Frank
PS My earlier "urinal flush mechanism" problems [nothing to do with an
aging prostate!] are well on the way to being solved thanks to your
replies. I just have to remove a stubborn 22mm olive on the existing
pipework!
The Medway Handyman
at an angle. I propose to replace the flush pipe with an L shaped one
see how that is sealed and cannot locate a replacement part in any of
the plumbing catalogues - well screwfix & toolstation actually. Flush
pipes seem to be 1 1/2" diam. How is this join sealed?
You can buy a complete kit from a decent plumbers merchant.
http://www.bes.co.uk/products/121.asp scroll down about 3/4 of the page to
'Flushpipe' and below it 'Flushpipe to Pan Connectors'
The top end uses a tapered rubber seal & compression nut just like a
compression join or elbow.
how is it used.
The botom uses a push in 'Flushpipe to Pan Connector' - the finned one sems
to be more common IME.
Things may have changed in 40 years :)
My Goodness Dave - The Medway Handyman. If I had only known about the bes supplier you linked to there... I ended up making a very tight R/A 1.5" flush pipe, using some standard 1.5" pipe, with a 1.5" push-fit R/A coupler. But of couse, one seemed to be 1.5" I/D and the other was O/D, which meant that they didn't fit eachother. So, we greased up a tabasco bottle, heated the pipe until soft, and then pushed it over the bottle and cooled under water. The resulting flaired pipe fitted so perfectly, that I still cannot believe it myself!
