edee said:
I have been replacing the outlets in my living room/dining room. I thought I had it but my circuit tester (plug in type that shows different combinations of lights) is showing no lights lit and a message of "open hot" on the legend. I lost my instructions to decipher what this means. What should I be looking for to correct this?
It means the outlet is dead. Perhaps the black wire is disconnected or the circuit breaker is blown.
These testers check three things;
1. lamp 1 on -- voltage exists between HOT and NEUTRAL
2. lamp 2 on -- voltage exists between HOT and GROUND
3. lamp 3 off -- no voltage exists between NEUTRAL and GROUND
Note:
HOT = narrow blade = black wire
NEUTRAL = wide blade = white wire
GROUND = rounded blade = bare wire
