Ceiling fan with light
Doug
I have a ceiling fan with a light that has 2 separate wall switches
.... one works the fan (on/off) and the other works the lights
(on/off). There are no other switches. Well there is a draw string
you can pull on, that only works the fan speeds.
I presume these wall switches are each just 2 way switches? I ask
because I may want to put a timer on just the light switch without
affecting the fan switch. Am I correct?
E
Erik
Probably just a 2 way, but take off the wall plate and have a look to be
sure.
Erik
RBM
They are called single pole, and yes you can replace the switch with a timer
John Carter
When we built this house, the electrician set up each room in a similar
manner. Don't know what type switches, but it was and is still
confusing. All the fans have a remote control for both the light and
fan, so we ended up keeping both wall switches on all the time and used
the remote to turn light and fan on/off as well as dim the light and
change fan speed - whichis basically whay I told him I wanted
initially.
Doug
Thanks all for the help and correcting me !!!!
H
Hot-Text
Yes you can if you have 3 wires..
But you have to know how to do it,
