Capacitors
  • Thread starter The Medway Handyman
  • Start date
The Medway Handyman
Hi All
I have an acquaintance who is trying to repair a Bosch pressure washer.
The faulty component appears to be a capacitor rated at 25uF. Not sure if
it's a start or run capacitor. Maplins stock the same make but only in 20uF
or 30uF.
Can either of these be used instead - and which one?
TIA
Dave
The Medway Handyman
www.medwayhandyman.co.uk
01634 717930
07850 597257
F
Fred
The Medway Handyman said:
Hi All
20uF or 30uF.
TIA
Probably - yes as all these devices have a wide tolerance. To be on the
safe side I'd use 20uF in parallel with a 5 or 4.7uF.
Do make sure you use the correct type!
Paul Herber
and voltage rating.
The Medway Handyman
the safe side I'd use 20uF in parallel with a 5 or 4.7uF.
Thanks Fred. How would I identify the correct type? What am I looking for?
Dave
The Medway Handyman
01634 717930
07850 597257
John Weston
The Medway Handyman, in article <YLl5g.62322$wl.42372
@text.news.blueyonder.co.uk>, says...
Hi All
or 30uF.
TIA
It's probably a motor run capacitor and so is designed for the
specific motor windings of the motor. If you go for a lower
value, the motor may not even run. If you go too big, it may
run unevenly due to an unbalanced rotational field or result
in a lower motor life, due to the higher current = heat. If
you look in CPC or RS components, etc, you should find the
correct value.
I'd experiment with other values if you have them available,
to check the fault is the capacitor, but if you are buying
one, get the right one. The voltage rating can be higher but
the capacitance should be as close as possible.
AFAIR, If it is a motor start capacitor, there will be a
second run capacitor, often in the same case (look for 4
terminals), and some form of contact that opens when the motor
is up-to-speed. Given the application, I don't think it is a
dedicated start capacitor, even in a Bosch :) Start
capacitors are less critical and you can normally use one of
higher capacitance without a problem.
raden
The Medway said:
Hi All
Not sure if
Sounds a bit high to me
The Natural Philosopher
The said:
Hi All
or 30uF.
TIA
Either. Needs to be 400v AC rated
The3rd Earl Of Derby
The said:
Hi All
washer.
sure if it's a start or run capacitor. Maplins stock the same make
but only in 20uF or 30uF.
TIA
Is it yellow and squarish in shape? if so my guess is its a spark
suppressor cap and 30uF will suffice.
robgraham
That sounds unlikely with the size of capacitance given. Spark
suppression capacitors require a low ESR to absorb the RF and a
capacitor of 25uF is not going to have that typically. Spark
suppressors are normally in the 0.1uF range - further I doubt that
pressure washers use universal motors so there are no sparks to
suppress.
I converted a 2kw motor from a broken pressure washer to run my
circular saw some time back. In doing so I had to replace the timer
capacitor and the start/run capacitors. The timer capacitor in my case
was in an electronic circuit and was small - the start/run capacitors
were like the ones shown in the Maplin advert and were of that physical
size, voltage and tolerance. If it is a timer capacitor it is most
likely to be electrolytic and have a tolerance in the order of 50% or
more, so any of the values given will do.
The Maplin site has a website http://www.lcrcapacitors.co.uk/ - see
if that gives any guidance on the accuracy requirement of start/run
caps. As pressure washers are run for quite short periods I wouldn't
have thought that a slight change would have made much difference and I
would go for the 30uF.
Rob
Dave Plowman (News)
Sounds a bit big to me for RF suppression. The range of these tends to be
about 0.01 - 1µF.
well its always nice to see complete and utter ignorance displayed on
the forum isn't it?
raden
the forum isn't it?
What forum ?
it's a newsgroup
raden said:
What forum ?
it's a newsgroup
Whatever. I switch between usenet and other web based discussion areas
so much. sometimes I forget which one I'm in.
capacitor 7
Capacitor shortage? 31
Capacitor Replacement 31
motor capacitors 16
Capacitor sizes 42
Capacitor Erratti... 28
blown capacitor 16
Condensor Capacitor 19
