Can you screw into exterior grade 18mm plywood?
dog-man
Having never worked with plywood, (Sheltered life) I need to ask if it
is possible to drive screws into exterior grade plywood 18mm thick?
I want to attach some battens to it, onto which will go pvc cladding.
Would I perhaps be better off nailing the battens onto the plywood?
Steve............
meow2222
either predrill pilot hole or use thin screws. And be sure to use left
handed screws on ply.
NT
Colin Wilson
And be sure to use left handed screws on ply.
Eh ? (curious !)
meow2222
Lobster said:
(e-mail address removed) wrote:
Go on then - I'll bite: what's that all about??
David
heh, I didnt think any of us lot would bite. Poor man :(
NT
Dave Fawthrop
Ha! Ha!
Guy King
The message <[email protected]>
Yes - but screwing into the edge isn't good - it splits.
Richard A Downing FBCS CITP
NT
No, no, no. Only ever use left handed screws into the right hand end
grain. If you use left handed screws into the left hand end grain the
glue goes west.
R.
Shokka
Use screws..galvanised (Or similar) would be best as they are being
used outside.
shokka
Shokka
glue goes west.
Remember to use a magnetised screwdriver bit with the 'n' pole nearest
the screw ('s' pole if u r in the southern hemisphere.
shokka
The Natural Philosopher
Either. Its bloody tough stuff.
Wore out three bits on my screwdriver ramming 3" screws THROUGH it
making a shower base..should have drilled pilot holes....
Dave Fawthrop
|> glue goes west.
Ha Ha.
manatbandq
Alternatively, screw through the ply into the battens. Depends how
thich the battens are.
MBQ
