HI Moggies
On Fri, 19 Jan 2007 07:27:40 +0000, Nicknoxx Nick@6&7.net wrote:
moggies 13 wrote:-
We've had a combi boiler installed. Our multifuel stove (Charnwood DX50iB) has a back boiler which has been drained and disconnecte from the central heating system. Can we use this stove occasionally as a wood burner?
You can but you will probably damage the heat exchanger so it won't b
any use as a boiler again. Should be fine as a stove-
You also might want to make sure that 'disconnected' does not mean 'and the pipes from the boiler stopped off'.....
Kind of a catch22 situation really - 'cos if the pipes from the back boiler are free to vent any steam etc that'd generated, you need to be prepared for a nasty smell in the house as years of crud burn / boil off the inside of the heat exchanger....
BTDT !
Adrian
