Boiler type - How to Run 4 Showers?
Gilmour Andrew
As House Convenor at our local cricket club we are trying to resurrect
an old shower room (we need 2 rooms now since the girls have equal
rights - good thing too).
The existing CH system only just copes with three existing showers,
heating and the toilet hot water demands so we want to put in a new,
separate boiler for the new shower room. Question:-
What is the best boiler system to serve a shower room with 3 or 4
showers running at one time?
Anu answers much appreciated,
Gil
Greenock Cricket Club
Bob Minchin
Gil
Use a system boiler (not a combi)
Either one with enough instant capacity
or a smaller one with a big thermal store timed to come on early when
you are going to need showers. Otherwise switch off the store when you
want rads only.
Need to cost out the options. Simple big boiler might turn out cheaper
and less controls/pipes and no tank.
Bob
Andrew Gabriel
Are they each going to be used once, or will each be used multiple
times in succession?
How good do they need to be in terms of flow, e.g. probably don't
need drenchers, but is a low/economy flow rate acceptable?
What energy supplies do you currently have?
Gas: domestic or larger industrial supply?
Electricity: single or 3-phase? current rating?
What is the existing heating system, and what's the boiler model/size?
Gilmour Andrew
The showers would be used all at once - we are talking about cricket and
hockey teams so probably all showers on for a succession of people, I
would guess all showers would need to run for half an hour. Way too long
for an electric option.
The current system is a gas boiler feeding a huge hot water tank on the
floor below. That system supplies the home team shower room (three
showers), provides the central heating to the bar, changing rooms,
toilets etc., and provides hot water to the toilets. I do not, off hand,
have the capacity of the existing boiler but from what it does already
it would seem to have enough on its hands. From memory it is the size of
a standard domestic, wall mounted boiler.
When the shower room we are trying to refurbish was last used it pumped
water up (electric pump) from the hot water tank below before running it
through a blender in to the shower room. It was generally felt to be too
much for the whole system - low on water pressure and too quick to empty
the water tank below if everything was running at once. This is why we
are trying to establish a separate, gas fuelled system for the upstairs
shower room.
Cheers,
Gil
Andrew Gabriel
shower room.
You are going to need a lot more information about the current
system, the capacity of your gas and water services, hot water
storage capacity, cold water storage capacity, etc.
You probably need to engage an industrial heating engineer to
look at the existing system, see what can be reused if anything,
and draw up a specification.
jagga009
