Boiler noise
Jampot
I put some stuff in my system to stop "kettling" about 7 days ago, it's
still popping and banging do I need to give it a bit more time?
E
Ed Sirett
Christian said:
We need more information about your system. In particular, the type and age
of the boiler, the bypass arrangements, the type of zone valves you have and
when the system was last properly serviced.
.... and what you added.
BillR
it's still popping and banging do I need to give it a bit more time?
It didn't work for me either.
Eventually I had to replace the pump and did so with one with a higher head
rating.
That seems to have alleviated the problem greatly.
I can only assume the flow rate through my conventional boiler was not high
enough..
Boiler Noise 3
Boiler noise 15
Boiler Noise 4
Boiler noises 1
Boiler noise 2
Keston boiler noise 1
combi boiler noises 3
Keston boiler noise 4
