Boiler Noise
N
NickWW
Hello all,
I have a Gloworm 80E boiler in my house. When the heating kicks in a
noise resonates throughout the house (sounds like it is from the
boiler) the noise sounds like a hoover starting up and shutting down.
Also slight bubbling noise. Only happens every now and again but very
annoying. Could it be the pump? The rads dont appear to have any
airlock and they are red hot.
I'm a very basic novice on these things and I wont be attempting
anything out of my depth. I just want a rough idea before I call
someone out.
Thanks for you help people.
Nick
O
Old Bill
NickWW said:
Hello all,
someone out.
Nick
could be air in the system or maybe the pump is begining to fail.
http://www.diynot.com/pages/pl/pl034.php
RedOnRed
I've had similar noise problems with my boiler. However, my boiler is 28
years old, so it's lucky to be working at all.
I have found that there is one particular radiator that seems to need
bleeding weekly. Providing I do that then the boiler mostly seems to stay
quiet.
The boiler also has what's called kettling when it first comes on. Which
basically means it makes a noisey knocking noise but then quietens down. I
found Fernox Boiler Silencer...
http://www.fernox.com/?cccpage=sc_boiler_noise_silencer&sub=9
to be quite effective at sorting that out. It's available from any plumbers
mecrhant or large DIY place. Is easy to apply and costs around £25.
N
NickWW
Thankyou both for your valuable help. What i have done is knock the
pump speed from '3' to '2' It is now much quieter (but still there,
setting 1 was simply too low for the flame to maintain heating). Also
with regards to 'Kettling' I would'nt go as far to say it bangs at all
or rattles, more like a boiling with air bubble noise when the heating
kicks in.
If the pump is faulty would it still provide red hot heating to all
rads, upstairs and downstairs?
BTW its a Gloworm 100E not 80E (ive got the pressure at 1.5 bar as
recommended in the manual).
Thankyou chaps
Boiler noise 2
Boiler noise 15
Boiler Noise 4
Boiler noises 1
Boiler noise 2
Keston boiler noise 1
combi boiler noises 3
Keston boiler noise 4
