boards for making a shed type thing
Gazz
i have a sort of lean-to at the end of my garage, it was origionaly a dog
cage for a gun dog, very roughly poured concrete floor, 5 galvo'd steel
posts, and those mesh type panels found on temporary fences... sort of,
anyhoo, not owning a dog that needed caging, i promptly removed the mesh
panels, but kept the uprights, and planned to attatch boards to the uprights
(first i'll prolly fix some timber so i only have to drill the metal posts a
couple of times)
i'm wondering what would be the cheapest boards to use, but not look too
naff,
i could just clad it in sterling board, but that would make the garden look
like an alotment (which it does now, and a cross with a fly tipping site,
but that's going to change soon, as my new GF is good with gardens)
i was thinking gravel boards, feather boards, old scaffold planks etc.
i have a router table, table saw, compound mitre saw and so on, so can
modify any straight planking into a style that will allow an overlap for
water to run off and all that.
Any suggestions for other boards to use, cheapness is paramount here, but
not if it's going to look really naff,
i'm in nottingham if that helps.
shazzbat
uprights (first i'll prolly fix some timber so i only have to drill the
metal posts a couple of times)
naff,
look like an alotment (which it does now, and a cross with a fly tipping
site, but that's going to change soon, as my new GF is good with gardens)
Pallets [1]. Especially the long ones used for plasterboards and the like.
Readily available now they mostly don't have a deposit. Get round your local
industrial estate(s) and ask wherever you see a pile of pallets whether you
can have some. Tell them it's for your allotment, they think you're a pauper
and are more likely to give you stuff. The worst that can happen is that
they say no. Same applies if you see a skip in someone's garden, they're not
attached to the stuff in it.
But if you want something you can buy the required quantity in one go, I
would say featherboard.
Steve
[1] Not blue ones.
The Medway Handyman
dog cage for a gun dog, very roughly poured concrete floor, 5 galvo'd
steel posts, and those mesh type panels found on temporary fences...
sort of,
mesh panels, but kept the uprights, and planned to attatch boards to
the uprights (first i'll prolly fix some timber so i only have to
drill the metal posts a couple of times)
too naff,
Feather edge - 50p a square metre (equivilant) in Wickes. Treated timber so
it won't rot, splash some cheap timber treatment over it if you don't like
the colour.
Gazz
so it won't rot, splash some cheap timber treatment over it if you don't
like the colour.
Cheers for that heads up Dave,
I've found a possible source of old scaffold boards from 2 quid a length,
but dunno anymore than that, i.e. what condition they are in, what length is
useable etc, they are from a scaffolding company, so not nicked or owt, BUT
it'd be a bit of work to make them work for my purpose, feather boards would
be a lot easier to use, and look a lot less like an allotment shed.
shazzbat
is useable etc, they are from a scaffolding company, so not nicked or owt,
BUT it'd be a bit of work to make them work for my purpose, feather boards
would be a lot easier to use, and look a lot less like an allotment shed.
The shed on my allotment is featherboard. You're not fond of allotments, are
you?
Steve
Gazz
are you?
'fraid not, my garden looks like one atm, last owner had ploughed it, put a
shite heap at the end with the tarmac from the drive under it, massive
compost heap, and loads of crap from when he left and had a massive bonfire
in the middle and tried to burn everything.... lots of metal all over the
garden as a result,
mind, some allotements are nice, neat rows of veggies, not a weed in sight,
nice looking shed,
but then there;s the ones that were at the end of my parents house when i
was growing up, 90% of the sheds made from old doors, bits of couregated tin
from old pig shelters, and the one opposite the end out our garden, his shed
was a couple of mk1 transit chassis half dug into the earth... he was made
to remove them eventually and build a 'proper shed' but he did it out of
scaffold planks planted upright in the soil.
just an allotement is nice in the right area, a residential place with 2
rows of bungalows that back onto each others gardens, where all the gardens
are nice and neat, green and lush, then there's mine, a right shit hole, so
i want to make it look as nice as i can.
Gazz
Muddymike said:
If you want to turn a "shit hole" into nice use T&G boards. I did and
ended up with this
http://share.ovi.com/media/Muddymike.Workshop/Muddymike.10461
There are several more pictures there showing how I built it. Not cheap
but I enjoyed building it and have something that should last many years.
The window was the only salvaged item and that came from the house when we
extended so matches nicely.
Mike
bloimey, wish i had room to build something like that in the garden, well i
do, but there wouldent be much garden left.
had thought about T&G boards, but dismissed them on cost grounds, tho i
could make scaffold planks into T&G with a bit of work on the router table,
measured the thing up today, and it's a bloody odd size, 1.47meters between
upright centers, so i need 3 meter long planks to do the end,
tho i could use 1.5 meter long boards, just works out more expensive, so for
cost things scaffold planks are looking best, just needs a bit of work to
make them look nice,
or i could just board it in sterling board, then splodge some really thick
paint on them to hide the 'grain' then see how artistic my GF really is, and
see if she can paint on T&G lines with knots and shadows showing :)
geraldthehamster
and ended up with thishttp://share.ovi.com/media/Muddymike.Workshop/Muddymike.10461
cheap but I enjoyed building it and have something that should
last many years. The window was the only salvaged item and that
came from the house when we extended so matches nicely.
Mike
Excellent. Is the little shed still inside it? ;-)
Cheers
Richard
Chewbacca
Muddymike said:
No. I left it there as long as possible to minimise the length of
time the content had to be stored elsewhere. Having dismantled it
I decided it was too good to scrap and cut off the bottom 4
inches which were rotten and re assembled it in the back garden
on an old concrete base without the original rotten wooden floor.
With the door converted to double doors its now the ride on mower
garage. See
http://share.ovi.com/media/Muddymike.Garden/Muddymike.10594
Mike
Someone has a lot more house than me..... Banker
