Bib Tap - small screw
Andrew May
I have just replaced a bib tap outside the house. I notice that both the
one that I took off and the new one have a small screw on the underside
of the tap near to where it connects to the supply.
Removing this screw reveals a small O ring around the screw and hole to
the water inlet.
But what is it for?
Dave Liquorice
Perhaps to drain the tap/pipe for cold spells.
You could just open the tap. But some Bib taps have a built in double
check valve this could be to drain the bit between the two valves.
Andrew May
That would make sense although I have a feeling that one did have a
non-return valve and the other did not.
It was the failure of the non-return bit that prompted its replacement.
A little O ring that seals it closed was coming loose and I was bu**ered
if I could find a way of getting it all apart to replace it.
Andrew Gabriel
This is what I believe it to be: to drain the non return valve.
It's also to check that both sides of the double check valve
are working (like you do;-). Without access between the two
valves, you can't test they both still work.
I think it is preferable to use a tap without a valve and install a
check valve inside the house to minimise the chances of it freezing?
That is the requirement nowadays - the double check valve must
be indoors, as they are otherwise silently destroyed by the first
frost.
At least, that's what I have done. The taps without an integral check
valve (ime, ymmv, etc) do not have this drain nut.
Fitted one for my brother a couple of weeks ago, and used a
separate double check valve on the indoor pipework. The
brass casting for the tap had a bulge where the access nut
would be, but it wasn't machined out.
The ones on double check valves usually have fibre washers
IME. Not seen one with an O-ring like the OP's.
Andrew Gabriel
How would you test this? Remove the tap and apply water through the
"wrong" end with a hose pipe and if it comes out the drain hole, the
first valve is broken; if it comes out the "back" of the tap, both are
broken?
I've never heard of testing them before. Is it done on installation or
is it supposed to be done annually?
I don't seriously believe anyone does, hence the sarcy comment.
