Benefit of extra Freon?
signots
OK I have a 25 year old house in suburban Chicago. Central AC is about 22 years old. I had it serviced Friday for the first time in a long time and I'm 2# short which the tech added (I wasn't home so thus my question). I knowthat fluids for everything need to be at the full level (oil, coolant car,for example) and I understand what happens if oil or coolant is low. What's the harm/ benefit to my system to have the correct amount of Freon? Will it run better, cooler, avoid future problems, what?
Tony Hwang
OK I have a 25 year old house in suburban Chicago. Central AC is about 22 years old. I had it serviced Friday for the first time in a long time and I'm 2# short which the tech added (I wasn't home so thus my question). I know that fluids for everything need to be at the full level (oil, coolant car, for example) and I understand what happens if oil or coolant is low. What's the harm/ benefit to my system to have the correct amount of Freon? Will it run better, cooler, avoid future problems, what?
You answered your own question.
Tony944
Think of your car will it run better with oil in crankcase or without
also same for gas will run better or worst without the gas in a tank.
I don't think that you are need or require explanation there.
signots
Tony H and Tony 944: thanks!
TimR
Down 2 pounds?
that's a lot, it might have only held 4.
Hope they fixed the leak.
The Daring Dufas
Down 2 pounds?
I've actually had good luck with Cliplight stop leak in many systems
with tiny impossible to find leaks. Yea I know, any leak can be found
but if the time and labor to find a tiny leak exceeds to cost of the
stop leak, I'm going with the stop leak. ^_^
TDD
TimR
TDD
Down 2 pounds doesn't sound like a tiny leak, though. It shouldn't have been cooling at all.
The Daring Dufas
I find a lot of those leaks at the service valves. For some reason a lot
of repair techs don't test there first. I have a tool that lets me
change the Schrader valves without losing any refrigerant. ^_^
TDD
Too much or too little refrigerant and the system does not perform well . May damage / accelerate wear , also .
With a system with a tiny / very slow leak , I can see adding a tiny amount of extra refrigerant to try to compensate a little , for the leak . But I am talking about a very small amount extra . Not enough to significantly reduce performance of the system or cause mechanical issues .
God bless
Wyr
