Roger said:
Sounds like a service is long overdue! Turn it off until it's been seen to.
Among other things, it sounds as if the heat exchanger is at least partially
blocked by soot, and needs a thorough clean. Chances are that the air intake
is also blocked, causing the flame to be too yellow - which will add to the
soot. Vicious circle!
At very least, it needs servicing. Ideally it needs replacing. Baxi Bermudas
are hopelessly inefficient compared with modern condensing boilers. The
feasibility of replacing it will depend on how easily you can find an
alternative suitable location for a new boiler.
We replaced our Bermuda with a new boiler elsewhere about 15 years ago. It
will soon be time to replace the replacement boiler!
When we replaced our old boiler due to failure I looked at the cost of
replacing it, the replacement's expected lifetime and the reported
reductions in gas usage.
Even allowing a relatively low efficiency of the old boiler, and a 20
year life of the new one, it made no financial sense to replace an old
boiler just for gas efficiency reasons. I think £2k is a reasonably
fair price people quote on here for a boiler replacement (often higher
actually). Over 20 years, you'd need to save £200 per year (£17 per
month) in gas bills to recover the cost of the boiler, by which time
you'll then need to replace it!
In fact, many people dispute whether modern boilers are more
reliable/have as long a life as older style boilers. Are new boilers
expected to last 20 years, or more likely 10-15 (requiring a £300-£400
annual saving to recoup costs)? With all these PCB/fan failures you
hear of costing £100+ to fix each time, you wonder whether they're
actually saving people money.
Then you're ignoring the environmental cost of making the new boiler
(metals, energy, transportation, disposal of old boiler...)
Of course, if the boiler actually needs replacing due to failure/serious
old age etc, then it makes perfect sense to replace with a model which
is as efficient as possible. It just doesn't make sense the adverts you
see about "Replace your current boiler today and start saving!" if the
boiler still has some years left in it.
