Baxi Bermuda problem
Steve
Hello,
We have a Baxi Bermuda 50/4E back boiler and Bermuda "Inset 2 Super" gas
fire. All electronic.
This has been installed for about 5 years by CORGI engineer and it is
the first problem we have had.
When cool, the boiler lights first time with the reassuring "whoosh"
that we have grown used to but after about 10 minutes it cuts out and
then repeatedly tries to reignite, fails, then tries again etc. The
sound is just that of a flame being blown out or running out of fuel, if
you know what I mean! Left for another 10 mins to cool, the boiler will
re-fire and run for, say, another 10 mins then the problem starts again.
Hot water and heating are both affected. The motorised valves are OK as
I can get either/both hot water and/or heating from the boiler whilst it
is running. I have also purged air from the radiators and also from the
stub by the pump (which by the vibration and temperature and also rads
getting warm would indicate that the pump is working OK) to no avail.
It was suggested to me by a friend that the "Gas valve" has failed. This
seems unlikely as I can hear our gas meter making the normal (money
gobbling) noise when gas flows each time it tries to ignite. Between
attempts, the meter is quiet. This would suggest to me that the gas
valve is OK.
I am not going to tinker with a gas appliance, unless this is a simple
well known problem that does not require anything other than a part that
can be changed by me without any problems and I doubt very much that
will be the case :-(
What would the normal cause of this problem be?
How much would a good engineer charge?
Any info or advice very gladly received before calling people out!
Thanks Steve
TonyB
Steve said:
Hello,
valve is OK.
Thanks Steve
Sounds like a sensor has failed, assuming you haven't got a blocked gas
pipe. Some are optical and get soot on them and just need a clean, but all
the same it needs a professional. Sorry.
TonyB
