dando
I'm going to lay a good grade of Armstrong sheet vinyl. Its not perimeter
bond. Needs adhesive underneath all. My bathroom floor is not level, and
unfortunately, angles toward the tub and towards a corner of the tub that
is tucked back in a small area between tub and vanity. Being that it's in
a rental unit, I'd like to change that. Last tenant didn't think not using
a shower curtain liner tucked into tub would be a big deal. I'd like to
have the water not all gravitate right next to the tub and the corner where
it's less likely to be a *bother* to tenants that don't have their heads on
straight. However, I'm not up for tearing out the subfloor to the joists
and doing it right. I plan to remodel the bathroom in the future, and that
will wait until then. For now, I want a fix that will hopefully last a few
years until I remodel.
The bathroom is about 4.5' wide, sloping downward from the left end of the
tub to the right. I can't correct the whole thing, but plan to use some
pyramiding of 3/16" or 1/4 underlayment material to get the right side
where the vanity and deepest corner are level very slightly sloping back
towards the left side, so that I don't have water finding it's low point at
the edge of the vanity and trying to get underneath it. [The pyramiding
will be beneath the final solid sheet underlayment layer that will go from
one wall to the next. It will be almost entirely under the vanity and
tight space between vanity and tub that will get no foot traffic, except
for a few inch transition beyond the vanity.] In this way, I will end up
with both sides sloping slightly to the center.
In other words, it won't be perfectly flat. It will gently slope about
1.5' from left wall to about a 1' level area where the person will be
standing in front of vanity, and then start gently sloping upwards again
for the remaining 2' to the right wall (beginning a few inches in front of
the vanity.
So after that unwieldy description, my question is, is this a big deal?
Having a perfectly flat floor is supposedly a necessary prep for Armstrong
sheet vinyl, but is it *really*? What terrible things will happen if I
follow my plans, and what "physics" would be at work?
Again, I really just need this to last a few years in a tolerable condition
for a rental unit until my resources and *time* are there to remodel.
Thanks!
the vanity.
Thanks!
